So there is a new model 211 coming out in a couple weeks. 38 pounds. Smaller and more efficiant. My question is should I wait or go buy the current 211 which comes with a voucher for a free spool gun???? That offer ends today.
Millermatic 211.
Originally posted by Jc2094 View PostSo there is a new model 211 coming out in a couple weeks. 38 pounds. Smaller and more efficiant. My question is should I wait or go buy the current 211 which comes with a voucher for a free spool gun???? That offer ends today.Miller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
possibly a link.. with more info...??.
I bought the current model today, figured I was a fool not too. I bought $400 worth of gear so I'll get a $400 rebate and the spool gun.
As far as specs in the new 211, I know it will only weigh 38 lbs. Upgraded drive system, supposed to be more effecient.
I for one would go with the older transformer. I have one and have no doubt it will outlive my Dynasty and CST 280, I think the inverters lifetime is shorter, I keep mine in the house and the 211 in the garage. Living in the south I would imagine long term heat exposure will shorten their lives.
I now await the usual onslaught of those who believe they are wiser.
I feel your pain
Jc2094- I know exactly what you were going through. I was waiting for months to buy a new welder and thought that they might be upgrading the 211. I just got the older 211 the other day and haven't taken it out of the box yet. I have a few days left to send in the rebate form for the $ and spool gun. Now I am wondering if I saw that the inverter model 211 came out and I am wondering if I should return it and get the new one. I guess at the end of the day, you just need to go for it and live with the decision. Good luck in getting your new machine!
MBV2MTN
Re: 211...
I bought mine on the last day for the rebate/spool gun. Got the rebate check and am awaiting the spool gun. I also bought the cart.
I'm not a pro at MIG, but I think it works well...sigpic...John
Lincoln SP135 Plus
Victor O/A outfit
Dewalt chop saw
US Navy '65-'69
Tonkin Gulf Yacht Club
USS Intrepid '67
Some Advise Please!.....Millermatic 211...Thanks
Hello, I'm new to this site and would appreciate any help you can give me on the following questions. I've been using the 211 for about 6 months or more now and have run into a couple problems:1) The M-100 mig gun the machine comes with is CONSTANTLY having feeding problems. Either with flux core or gas I am changing tips 0.035 at a rate of 2-3 an afternoon. If I don't than it won't feed smoothly or sometimes not at all causing the wire to back up in the machine. I have tried various tensions, sprays, and gels, but all the same?2) Is there a better gun than the M-100 it comes with I can replace (I'd prefer longer leads anyway)?3) I see there are a couple different tips that can be used depending on if I'm using gas or flux core could this help protect the tip and my feeding problems?4) I'm beginning to weld a lot more and I'm considering on upgrading to another machine that also does TIG mainly for aluminum and fine light gauge steel. Would the Mulitimatic 200 with the TIG kit be a good option. My concern with buying the aluminum spool gun for my 211 is that I heard it does not produce as nice of a result as a TIG machine?SORRY LAST ONE!5) I've been buying these cheap auto darkening helmets that quickly get scratched and/or burned than can't see well. Usually I can't find replacement lenses and if so its a pain to have to keep cleaning and changing them......is there a better option or advantage to buying a better helmet?Thanks I'd really appreciate your feed back as I've turned my machine off until I can get more into and on the above!..............bowfinger
The m100 gun is not your problem. Based on your questions I'm gonna guess you need more practice. What kind of settings, gas, wire, base material, are you working with? Sounds like you might have the wrong drive rolls, wrong polarity or wonky voltage and feed settings.
The MM200 will not work for Aloominum Tig. It is a DC only machine.
You'll need an AC Tig machine.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Thanks Will Get Back To You!
Originally posted by Cgotto6 View PostThe m100 gun is not your problem. Based on your questions I'm gonna guess you need more practice. What kind of settings, gas, wire, base material, are you working with? Sounds like you might have the wrong drive rolls, wrong polarity or wonky voltage and feed settings.
Hi Thanks for getting back to me so quickly. Your right about needing practice I've stick welded for years, but wire feed while convienant isn't as easy and simple as one might think. I'll get all the info you suggested today while out in the barn and maybe it will give you some idea of where I'm going wrong.............Thanks again, I'm not much into forums and Social Media but really needed some advise....Take Care..
