Spoolmatic 30A
  • Spoolmatic 30A
    Can the spoolmatic 30A weld Flux core wire?
    Yes it can.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
      Any spool gun will weld either gas or gasless FC or steel wire or anything else that fits a small spool. One thing to check for if used with lots of steel is the drive roller wear. I now have a steel set and a set just for aluminum because the steel just wears them quicker...Bob
        Can anyone tell me if I can run Spoolmatic 30a on a Hobart handler 210
          No. Completely different control circuit than that required for the HH210.
          Syncrowave 180 SD
          *HF-251D-1
          *WC-1S & Spoolmatic 1
          PakMaster 100XL
          Marquette "Star Jet" 21-110
            Sure, just need a WC-24 and a PSA2
              Sure but I was going on the premise the OP was looking for something a bit simpler such as direct connect and not have to go hunt down a PSA-2 and sink more $$$ into a WC-24.
              There's a number of spoolguns that could be hooked up to the HH210 if one wanted to throw enough extra equipment and $$$ at it.
              Syncrowave 180 SD
              *HF-251D-1
              PakMaster 100XL
