So my seadoo has a hole in the tuned pipe. Going to need to fix it by welding a new welch plug in. Thinking i can use my w115 to control the spoolgun, will tie it into the spoolgun hookup for the contact closeure...we will see!
Kevin
Lincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
Wc115 will work just have to pop the steel side drive open and paper clip the steel sides trigger, or tape the trigger on the mugs handle. I make lots of adapters to modify the miller spool gun to fit what ever brand with spool gun facility's.
On the w115 i think it has a contact closure.. ie trigger wire going to hook that to the mp210's gun trigger harness and set it on spool gun. Should be plug and play. My wording might be wrong but basically looking on the schematic just using the closesure circuit from the spoolgun.
Kevin
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
Along time ago i bought the w115a because i figured it would make my spoolgun work on anything. Well it came through again, and it was easy, simply cut off the 14 pin, crimped on a lincoln gun harness connector, and the 30a ran perfect off the mp210.
Kevin
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
