I have a 252 that I cannot find an answer for. Tweco gun. It pops often. I have cleaned the ground connections. Changed the liner. It's really bad at start. Once you get a puddle started you really have to stay right in the center of it to prevent more popping. .035 wire, usually run about 20 Volts, 350-400 ipm. I also have a couple of 251's that weld great, same settings, same steel. Any help is appreciated. Tim
252 popping
Have you tried increasing your voltage. 20 volt seem a touch low. If you haven't tried it yet , try giving 21 -22 volts a try.
Also, you have adjustable run-in that you can try playing with, if needed, to possibly help improve the quality of the arc starts.
Originally posted by Danny View PostHave you tried increasing your voltage. 20 volt seem a touch low. If you haven't tried it yet , try giving 21 -22 volts a try. Also, you have adjustable run-in that you can try playing with, if needed, to possibly help improve the quality of the arc starts.
When my 251 started popping on starts I called Miller....they told me to take the hot start wire # 8 (yellow arrow ) or a # 79 wire off the contactor.
My 251 would pop and weld the wire to the tip almost everytime the trigger was pulled, removing the wire seems to have helped quite a bit, but it still will pop on occasion.
My 2003 251s' best looking beads are when it's in spray mode using 98/2 gas with .030 SuperArc® L-56 ER70S-6 wire. 99% of the time 1/2" steel is the thickest I ask it to weld.
I thought of putting a toggle switch on the machine so I could switch the hot start feature ON and off, but I'm getting lazier by the second and just about ready to pull the pin.Attached FilesLast edited by tackit; 07-19-2015, 12:03 PM.
Just because one machine welds good with the wrong settings doesn't mean another will. Your voltage meters are likely inaccurate on one or both machines. Start by turning down the wire speed until the popping or stuttering stops, then you are in the ballpark. What thickness steel are you welding? Your wire speed indicates 1/4" but your voltage indicates maybe 1/8".
Tackit I may try that.Originally posted by walker View PostJust because one machine welds good with the wrong settings doesn't mean another will. Your voltage meters are likely inaccurate on one or both machines. Start by turning down the wire speed until the popping or stuttering stops, then you are in the ballpark. What thickness steel are you welding? Your wire speed indicates 1/4" but your voltage indicates maybe 1/8".
