Acetylene Question
  • Acetylene Question
    A question that I should know the answer to.... but, I don't. For my Smith rosebud tip that I am using, the pressure chart calls for 15 psi on the acetylene. I know that much above 15 psi is dangerous. Now the question. When I have the gas valve open on the torch handle, the gauge reads at 15 as I set it. When the gas valve is closed the gauge spikes up to about 20 psi. Is this a problem?
    Acetylene Question
    No, perfectly normal. Unless it spikes drastically, then there may be a problem.
      Good question, when all the valves are closed, set it to 15 psi and you be safe, I'm 98% sure that if the regulator shows 20 psi when closed you are operating outside the safe limits.
      Make sure you dont have a propane regulator, they can look the same and allow you to operate at much higher pressure.
      The one I use for the big rose bud looks just like a acetylene but says propane when you rad the info.
      The line pressure gauge should be red after the 15 psi and above.
        Definitely an acetylene regulator. Thanks guys for the help. I used to set it and not worry in a shop setting but, as I get older and the fact that my kids are on the same property......the wreckless abandon has been replaced with caution.
          What is the consumption of that rosebud in CFH? Make sure your tank is large enough to safely support that withdrawal rate (1/7th or 1/10th rule). I saw some of the Smith rosebud specs and all recommended one or more 350 CF tanks. They also recommended high-flow flashback arrestors. Flow restrictions could affect your pressures.
          Miller stuff:
          Dialarc 250 (1974)
          Syncrowave 250 (1992)
          Spot welder (Dayton badged)
            USMCPOP....you hit the nail on the head. I only have a #4 acetylene cylinder and my rosebud draws 51 scfh.......I need 350+ cu. ft. To use safely. I was overrunning my cylinder's capacity. Im glad you brought this up. Coulda got ugly. Thank you!
              You may want to look into using oxy/propane - that's what I use for cutting and heating.
              Cheaper and no withdraw rate or overpressure issues.
              "Beware of false knowledge; it is more dangerous than ignorance." ~George Bernard Shaw~
              Airco 300 Heliwelder
              Dialarc 250 AC/DC
              ESAB 161
              Invertec v250 and v300 Pro
              SA200
              Spectrum 700 plasma
              MM210
              Miller HF-15-1
              Dirty ugly tools - perfect
                Good idea Dave!
                  Originally posted by Ironken View Post
                  Good idea Dave!
                  I've been using oxy/propane since the 90's and have never regretted making the change
                  A person can't weld with propane, but I've got mig, tig, stick so it's of no concern.
                  Dialarc 250 AC/DC
                  ESAB 161
                  SA200
                  Spectrum 700 plasma
                  MM210
                  Miller HF-15-1
