Originally posted by cruizer
View Post
Dimension 652 A/V meter trouble.
Just getting the meters to respond to the dial would be good enough for me. It's more a case of it bugging me that they don't work than it is of caring about the accuracy of the readout. I'm afraid that if there is a glitch in the meter circuit, then how do I know that something else isn't working right. I know, I'm OCD, I should just be glad that it welds right, haha. Thanks for the responses
You'd probably could zero the meters out yourself, but to calibrate it, you'd need a tech and a load bank
Occiliscope, been at this for 20 plus years, think I pulled out a Scope only a couple times. Your machine merely needs a calibration for the idiot Gage's. And that's all they are. Zero to do with actual welding.
Hello everyone, I'm a longtime lurker on the forum. I picked up a new machine to power my carbon arc torch. It's a Dimension 652, serial# LB092486. It seems to weld stick fine, and pushes the CAC great, but it has a problem with the display gauges. When the unit is turned on, the voltage reads 74 and amps read -1 or-2. This is displayed no matter where the A/V adjust knob is set. If I hook up a footpedal, and switch to remote it drops to 0 vollts, but as soon as you click the foot pedal to any setting other than off voltage climbs to 74. The arc responds to different knob settings, but the meters don't. I probably can't afford to take it in for repair, I would really hope that I can troubleshoot and repair it myself.
I have an oscilloscope, and can do some basic testing. I just don't have access to the tech manual. There is nothing obvious on either circuit board, and all connections are clean and tight.Any suggestions or ideas would be really appreciated.
Steve.Tags: None
