What guage wire do i need for 220 while running my plasma cutter and air compressor.
  • What guage wire do i need for 220 while running my plasma cutter and air compressor.
    i want to run my 110 compressor and my 220 miller 375 plasma cutter. The plasma i am running on 220. what guage wire should i be using running from my house to the garage. I have 8 guage now with 40 amp breaker.
    What is the distance from you house breaker box to garage breaker? I would have at least 100amp in the garage for a buffer if both are going at the same time and to not have the lights dim when in use and the demand gets high.
      I have a 100 amp breaker box in the garage. The garage is about 50ft from the house. My question is will a 8 guage wire from the house to the garage be good. I heard it will be fine.
        So you have a 100a breaker in the garage? I assume your 40a is for the 220 in your garages panel?
        I would want the heaviest ga. wire to supply the demand. I'm going with 0ga at a distance of 150ft, the lights dim in the house when things kick on at the same time now and that's annoying. My demand in the garage has changed since it was 1st done. You never know what else you may do later and you might as well set your self up for any demand change., but that is just me. 8ga will work for you now but mabey not later.
          My attached garage has a 100 Amp panel. It is about 75 ft. from the main panel. My electrician specified 2/0 aluminum.
          This will give you a rough idea of wire size, though it doesn't take into account the length.
          Ampacity is the maximum current that a conductor can carry continuously under the conditions of use without exceeding its temperature rating. Cerrowire's ampacity chart helps calculate the load requirement for a circuit.
          This is more detailed:
          I wouldn't put more than a 40A breaker on 8 gauge.
          Miller stuff:
          Dialarc 250 (1974)
          Syncrowave 250 (1992)
          Spot welder (Dayton badged)
            Here is another.
              So im assuming my 8 guage is plenty.
                I am no electrician so i dont understand what your saying
                  I personally would have done 4 or 6ga minimum for 50 ft length on 40A. Why did you decide on 8ga in the first place.
                  HTP Pro Pulse 300 MIG
                  HTP Pro Pulse 200 MIG x2
                  HTP Pro Pulse 220 MTS
                  HTP Microcut 875SC
                    You have to factor all things using power lites, welder, compressor etc. Let's say you compressor uses 20a to run when it first fires up the surge electric can be as high as 35-40a, and if you have other things using electric you can momentarily overload the line causing a brown-out or pop the main breaker. If you are using a welder at the time you also running the compressor you could be starving them and best case hurt the units over time worst case you melt the wire and have a fire. I'm not an electrician either but always over-kill the minimum requirements especially when it comes to electrical and always call one to be sure.
                    If you fill out the info in the link i provided it will tell you 1/0 wire, I think.
                      You are pulling power from your garages panel right? Or are you running a separate wire from the house breaker for the 220 in the garage? I'm not following this very good now.
                        I am puling from the garage panel. 8Guage wire coming from house panel to garage panel.
                          Something else to consider is I have 10ga wire going to the outlets for running just my 211 welder so running 8ga for supplying a 100a breaker panel IMO just won't really work well, but again I'm not an electrician but I surely wouldn't listen to Lowes or Home Depot people they might tell you 12ga will work.
                            If you are going from your house panel to your garage panel connect them with no less then 1/0ga IMO.
                              My miller 211 runs fine. i can run my plasma cutter and compressor at the same time no problems at all. Wire DOESNT even get warm.
