A guy dropped his old wood plane and it broke in half. The break is vertical on both sides. No chunks missing. If you fit together you can't tell it's broken. I need a simple way to try and fix this if I can. .I know I'll need to V groove it out . Can this be migged? I also have some brazing rods. I'm not going to put a lot into this. Just trying to save it as it. Suggestions. I really don't weld cast but once I did mig the cast power steering box on my old dodge van. It had a hairline crack and was seeping fluid. It's held.
Question on welding cast iron
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
and check out some of my ironwork and other stuffTags: None
Originally posted by Cgotto6 View PostI would really consider a high grade epoxy. If you can fit both pieces keyed perfectly you likely would have an undetectable repair.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
I'm sure they make a nickle mig wire but its not as easy as mig welding it up, you need to do the prep, preheat, weld, peen and post heat to do a good repair.
I just gave instructions about this a few weeks ago.
Dont waste your time with epoxy if its a tool meant to use, epoxy is a great product under certain circumstances, this is just not one of them.
Ya, we talked a little about this a few weeks ago with someone that had a problem with an exhaust manifold. Wonder how that came out?
If you're positive it's cast iron and not cast steel, then TIG braze your handle doohickey. I prefer aluminum bronze, on AC with the balance around 70-80% EN and the freq around 100. That's how I'd most likely do it. The aluminum bronze flows nicely once you get the puddle going and it machines back down pretty easily too.
I would certainly agree that pre and post heat is a good idea. Peening the aluminum bronze I haven't found to be necessary.
Let us know how it goes.
You can weld it, but you must 100% follow the proper procedure, if not ... you get more cracks than you started with...
You can get Ni MIG wire ... several years ago I looked into it and it was very very expensive and you could only get it in the big (11#) rolls ... I only needed a little bit, even the 2# rolls would have been overkill...
Brazing also works. So would JBWeld.
With JBWeld I'd worry about the fix not being strong enough; with brazing and welding, I'd worry about warping and distorting the plane body (brazing less so as it's not as hot). Pick your poison.
Frank
Monte, good to see you back on the forum. Thought we had lost you. Jasigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Originally posted by ja baudin View PostMonte, good to see you back on the forum. Thought we had lost you. JaNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
[Thanks to all that repliedNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
