Hello, I have a 80s model black face MM35. Serial number JH180973. I have a bit of an issue. I may outline details that are not necessary but id rather give to much info than not enough. Welder has been going strong for 2 years since I got it. I upgraded to a m25 gun with a 12 foot whip when I first got it.
Now about 2 weeks ago I was welding some 1/4 plate with the heat turned up. I made a root pass then a cover, weld was about 16 inches long and mabye a inch wide. At the end of the weld the machine just stooped feeding. No gas flow either. The heat lead was hot to the touch.
I checked for continuity at the switch in the gun and it opened and closed as normal. I checked the breakers and neither were popped. I opened it up and CR1 did not light up when I hit the gun trigger. Could this be a bad breaker? What is the next direction I should take? I need my welder back! Please help lol. Thanks
