Bought a Millermatic 350" w/o pulse " powered up fine during testing at sellers get it back to my shop and get it hooked back up and flip the switch and no power. I did have to open the side cover when I got it to the shop and change it over to 230v. I do have power going to the transformer in the back of the machine. Any help would be greatly appreciated.
Millermatic 350 will not turn on.
Originally posted by Jrodfftch View PostBought a Millermatic 350" w/o pulse " powered up fine during testing at sellers get it back to my shop and get it hooked back up and flip the switch and no power. I did have to open the side cover when I got it to the shop and change it over to 230v. I do have power going to the transformer in the back of the machine. Any help would be greatly appreciated.
Here is a video.. to doublecheck..
https://www.youtube.com/watch?v=zbvDug33Ntw
and that it is correctly wired for the proper phase?? NO RED wire connected for single phase..
Proper manual can be downloaded here if you plug in your serial number.. here
http://www.millerwelds.com/service/ownersmanuals.php
Also... have you reset CB1 (see manual)Last edited by H80N; 06-06-2015, 02:10 PM..
Originally posted by Jrodfftch View PostI did do the re-link as the video showed but still no luck.
Correct voltage coming out of the wall socket..??.
Maybe this one has no CB1...
have you cycled the power switch on the right hand side bottom corner of the front panel...??.
I figured it out. Where there machine was set up for 440 volts I had to pull the cover and take the red wire loose from the contactor switch and hook the white wire where the red wire was . Flipped the switch and now I have power. Still need to pull the contactor switch off and clean it since its humming to me. Thanks for all your help.
