Three compartment 16 ga. 430 stainless steel scullery sink. The right compartment is filled with a 1:32 bleach solution for disinfecting animal bowls. The weld at the bottom of the divider between the center and right compartment is cracking and water leaks between compartments.
What repair method would be most resistant to corrosion?
TIG? (308L filler?)
Brazing? (filler?)
Braze welding?
We will replace this sink with a 304 (or 316) stainless sink but that will take some time.
Thanks
solidstate
TIG? (308L filler?)
Brazing? (filler?)
Braze welding?
Thanks
solidstate
