I'm currently looking to purchase a MM251. I have been doing some research on how many amps I need to hook this welder up in my garage. From the Tech Spec. sheet it looks like a 50amp Circuit Breaker with 6-3 gauge wire will be good Since, if I'm reading it correctly that at 200v it pulls 48 amps, which would be the maximum amps the MM251 would draw.
From the Breaker Box to the receptacle will be about 25-30 feet. I spoke with a Electrician and he seems to think this will be fine. I just found this forum and would like to get the opinion of others.. I did do some searching to see if someone did post this question, but maily it seemed to be for the MM201
Thanks,
Bronco STD
Thanks,
Bronco STD
