I'm new to tig welding. I bought a multimatic 200. Learned a few tricks from some people and some settings. The question I have is about the argon post flow. The gas flows for approx. 8-10 seconds after the arc is finished. Is this correct and is there a way to change it? It seems longer than necessary. Any help?
post flow?
Definitely too long. I reckon it should be around 2-3 seconds. Best to consult the owner's manual.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
1 second per every 10 amps
Originally posted by the family forge View PostI'm new to tig welding. I bought a multimatic 200. Learned a few tricks from some people and some settings. The question I have is about the argon post flow. The gas flows for approx. 8-10 seconds after the arc is finished. Is this correct and is there a way to change it? It seems longer than necessary. Any help?
a few seconds more than your intuition may tell you will help to give you a sound shiny bead.. gas flow is measured in Cubic Feet per HOUR... so... it really is not as much as you may think..
Being a gas mizer could be a very poor trade against weld quality....
My bad, I was thinking MIG, not TIG, didn't see that part, lol.
8-10 might be excessive depending on the amperage, but also depending on the part. the 1-second-for-every-10A rule is not adhered to by everyone, I know I don't use it if I'm doing anything with mild steel that is "sufficiently" thick. If I'm near 100A, I might go 5-6 seconds if the part can wick away the heat on it's own from the thickness of the joint. If you're welding at 200A, the part you are welding is likely thick and heavy which acts as a natural heat-sink----you won't necessarily need 20 seconds of postflow, especially if it is just plain ol' mild carbon steel. Stainless steel is a different story, as well as other reactive metals.HTP Invertig221 D.V. Water-cooled
HTP Microcut 875SC
I don't think you can adjust post flow on the Multimatic.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
