I have a 135 with a wire feed problem. I can weld for a minute or so and the wire will slow down and stop soon after. I let it sit for a couple minutes and it will start to feed again and once again stop after a minute.
I tried feeding wire without welding and it will feed normally for about 15 feet then you can hear to motor slow down and it will stop. The tension on the wire is not tight at all.
I don't think its a gun issue or roller issue- it seems like an overheating issue. I've read it may be a board? Any advice would be appreciated.
