I am needing a starting suggestion for settings for welding up some 2" o.d. tubing 321 with .035 wall. All miter joints and some butt welds. I have a dynasty 350. I will be plugging and back purging. What size tungsten and what size wire. Thank you in advance.
321 stainless
that thin of a wall thickness, 0.030-0.035" wire, 347 alloy. I'd try to use pulse to stiffen the arc and reduce heat input. Ultimately it's up to you to try it out on scrap tubing first, but I'd try around 60-100PPS, 60A, 35-40% background, 40-50% on-time. Try it out on scrap, and fine-tune from there. Tungsten, anything good on DC such as 2%Th, 2%La, etc, etc will work just fine. 1/16" diameter, 3x taper length, pointed end.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
You will not need any wire. As long as you have solid fitups, walk the cup on it and fuse it. I weld process piping for a living and all 16/14/12 ga tubing is TIG welded without any filler. Adding filler will introduce more of a chance for the material to draw, especially if you have any gaps in your fit ups.
Such a thin wall will not need any more than 40-45 amps. 1/16" tungsten will be best, 3/32 will work. I use 3/32" 2% thoriated on everything from 30-150 amps. The arc just starts better at certain ranges. Majority of process piping is done with miller maxstar 150s using lift arc method.Stainless process piping - welder & fitter
Miller Dynasty 280DX
Jet band saw
Dewalt chop saw
Assorted IR air tools and Metabos
Originally posted by CODE4 View PostAdding filler will introduce more of a chance for the material to draw, especially if you have any gaps in your fit ups.
Walking the cup on a thin wall tube, I've never seen that done. I don't doubt you or your skills, just haven't seen that.
BTW I'd really like to see a pic of that weld on thin wall tubing, fused by walking the cup. I'd think walking the cup would be too wide, spend too much time on a thin wall tube, fusion joint. Post that pic!
If you had a 90° mitre joint, you'd walk the cup on that?Richard
West coast of Florida
