MM 350P with Mig and Spool Gun?
  • Danl
    Yes, I have been through the manual extensively. It doesn't cover two gun operation. I have assumed that one mig gun would use the large cabinet spool, and a spool gun would use the same positive lug for welding. Next I have assumed that there is a second bottle for gas the spool gun. The spool gun hooks directly to the gas regulator. The only other connection would be the control connection... I guess you just have to unhook the AlumaPro gun and then connect the spool gun controler, unless there is "Y" connector available. I see no practical way, other than a separate wire feeder to use a second mig gun...
    Your thoughts... Thanks, Danl
  • H80N
    Originally posted by Danl View Post
    How would you setup a separate spool for the steel wire. I would like to be able to just switch from one to the other. I cannot see how you can run a second mig gun along with the Aluma Pro. Here is a sample setup that I see on the MM 252... BTW my Aluma Pro gun is 25 feet and I have the standard mig gun that came with the machine.
    [ATTACH]35220[/ATTACH]
    Here is the manual
    http://www.millerwelds.com/om/o1327ah_mil.pdf
    See
    SECTION 5 INSTALLATION
  • Danl
    Yes... Mine has both.. plus regular MIG guns
    why run steel in a 30A when you could run a long MIG whip..?
    http://www.millerwelds.com/pdf/spec_sheets/DC12-51.pdf
Name:	MM252 with Spool Gun.jpg
  • H80N
    Can the MM350P be used in with a Aluma Pro Push Pull and a spool gun. I prefer the Aluma Pro for Aluminum and then have steel setup in a Spool Gun. Can that be made to work? If so how do you set it up.
    Thanks, Danl
  • Danl
    started a topic MM 350P with Mig and Spool Gun?
    Thanks, Danl
