Hello all,I'm new to this forum but have heard great things from people in the industry. I'm currently working in a manufacturing plant with a few robotic welding cells and a dozen or so manual welding cells. Is there any good way to test the ground to work pieces in high volume/high mix welding other than individual testing of conductivity with an ohm meter??? Thanks for the help!
Testing ground to workpiece
We are having various consistency issues and i am working on mapping out all the possible failure modes and the process to troubleshoot each one. The way our fixtures mount to our tables is by sitting on 4 small rest pins and secured by 2 bolts that keep the fixture in place with a tight tolerance bushing. I suspect the conductivity between the fixtures and the tables is very poor because of this. Our power sources are all OTC.
Problem is that all it takes is one machine to screw up the whole line, so its likely not a ground (work lead) error. I am thinking that one of your tables isn't isolated from a power supply. I've investigated this problem way too many times, and now is the first thing I look for.
Other than the usual metal spool on the feeders touching a chassis, however, this is an erratic error as problems occur as the arc is turned on and off.
If your running tubs of wire. the wire feeding is a steel liner encased in a rubber tube. The tube cuts easy and shorts to a chassis. The chassis could be anything, though being a potential ground, all machines are using the same ground, and presto, alota problems everywhere.
Originally posted by cruizer View PostIf your running tubs of wire. the wire feeding is a steel liner encased in a rubber tube. The tube cuts easy and shorts to a chassis. The chassis could be anything, though being a potential ground, all machines are using the same ground, and presto, alota problems everywhere.
