Source for silicon bronze angle or suggestions for tig welding brass
  • Source for silicon bronze angle or suggestions for tig welding brass
    My friend is a sculptor that has been tig welding brass angle together with silicon bronze rod for structural armatures for her concrete sculptures. She just purchased a Miller Syncrowave 200 and I was helping her set it. I had forgotten how horrible trying to tig brass could be. I suggested she try and find some silicon bronze angle but I haven't been able to locate any. Does anybody know of a source ? Or any trick for working with brass?
    Thanks,
    David Duncan
    I order my straight cut lengths of silicon bronze down to about 0.045" (or 0.035" can't remember) from www.weldingsupply.com out of Illinois. I also wanted thinner, but I had to get a MIG spool for 0.023", Blue Demon brand from Ebay.
    Brazing/TIG'ing brass you just have to keep the heat input to a minimum because I believe there is zinc in there that tends to boil out and spit up out of the puddle and ruin your tungsten/cup. Using pulse on a scrap piece first will usually help out.
    HTP Pro Pulse 300 MIG
    HTP Pro Pulse 200 MIG x2
    HTP Pro Pulse 220 MTS
    HTP Microcut 875SC
      Thanks,
      David Duncan
      Have you tried Alaskan Copper Works...??
      Alaskan Copper & Brass Company is a distributor of aluminum, stainless steel, copper, copper nickel, brass bronze, and other corrosion-resistant alloys. Forms include: coil, sheet, plate, pipe, tube, fittings, flanges, rod, bar, angle, channel and custom extrusions.
        Set the balance to minimal cleaning and weld on AC. If it were an inverter I would recommend 90% EN, 100Hz plus. But a Syncrowave 200 is stuck with maximum 60% EN (a "10" on the Balance) and 60Hz.
        Use enough amps to get the puddle started and flow CuSi into the joint. Don't worry about melting the parent metal or admixture; you are essentially brazing not welding.
        Dynasty 350
        Bobcat 250
        Maxstar 150S
        Titanium 9400
        Purox O/A
        Cutmaster 42
          http://www.alascop.com/index.php
          I've never used ACW to buy materials so I don't know if they'll sell small quantities.
          You might also look at Southern Tool Steel
          Richard
          West coast of Florida
          Website
            Bingo! That is how we do it as well.
            We did figure out that if we backfeed the bead and keep the arc buried in the filler, brass welds pretty good.
            Miller Dynasty700DX
            3 ea. Miller Dynasty350DX
            Miller Dynasty200DX
            ThermalArc 400 GTSW
            MillerMatic350P
            MillerMatic200 with spoolgun
            MKCobraMig260
            Lincoln SP-170T
            Linde UCC305 (sold 2011)
            Hypertherm 1250
            Hypertherm 800
            PlasmaCam CNC cutter
            Fadal Toolroom CNC Mill
            SiberHegner CNC Mill
            2 ea. Bridgeport
            LeBlond 15" Lathe
            Haberle 18" Cold Saw
            Doringer 14" Cold Saw
