millermatic 212 autoset.fed the wire out the gunThen it stopped rollers werent turning. overtemp light/autoset light come onflicker make alound click. come off/on when you presstrigger nothing happens
Millermatic 212 autoset wont work
Could be lots of things, unlikely to be the auto set though. Did you start your weld right away? Most of these units shut the arc and wire off if you wait too long, others shut the arc off and then go into jog. Does the unit work in other modes? Did you crank the wire down too much and over heat the motor? See a lot of stuff to consider...
