High amperage single phase plugs 60 amp.
Guest repliedLook at the Hubbell CS-8265C and mate locking connectors.
"My 50 amp plug single phase plug that I use on my miller matic 252, MM200 etc. The 50 amp plug is 50 amps per hot leg."
Not exactly true - 240 volt SINGLE phase has two busses that are 180 degrees out of phase with each other, so when one is positive the other is negative - either leg to ground/neutral would be 120 volts.
So with the Nema 6-50 you really only have ONE 50 amp circuit at 240 volts, and a ground... Steve
Guest repliedOne word:
HUBBELL
One reason:
THE BEST THERE ISLast edited by Guest; 05-26-2015, 08:32 AM.
There are some 100A ProPin 250V connectors on eBay for around $35. each. The pin spacing is different.
Originally posted by USMCPOP View PostNo voltage specs but a bit cheaper:
I see the Bates 100A plugs are 125/250V but are close to $50 each.
Doesn't look like they have an option to order 240v.
Originally posted by USMCPOP View PostWhat about 60 and 100 Amp Stage Plugs? Ed, do you have any input?
You can get 100amp 240v but he would need both female and male connectors.
$49.99 per connector.
Certainly a possibility if one really needs to disconnect but they are designed for #2 individual cord and I think the 350p has 6g wire in the power cord-might be 8g.
Originally posted by Portable Welder View Postokay then looks like I need to buy another Russel stohl plug and run it off that if I want to meet code.
Single phase 60 or 70 amp combos aren't cheap!
Applies to conductors and connectors.
Okay then, My 50 amp plug single phase plug that I use on my miller matic 252, MM200 etc. The 50 amp plug is 50 amps per hot leg.
