I just starting to use the pulse feature on my Miller 350P and I am really having spatter problems. Welding 12g mild steel tubing, .035, 90/10 gas, running factory settings, gas flow 30. Spatter everywhere. Getting a good spray fan pattern, buzzing sound. Got to be my technique..what can I try to improve?
Pulse spatter
Pulse spatter
Yes can be technique, with pulse you need to move pretty fast, try & stay on front side or leading edge of puddle. Also gun angle is very important.
Another possible problem is Arc length, you may be to close to puddle ie blowing splatter or kinda like stabbing the puddle. The chart is just starting point or very general. You will need to adjust arc length to suit your welding style. If I remember I'm not even close to chart when I got mine dialed in. It will take some work but stick with it, it's a great Michine.
I usually run mine: cfh 20-25, arc length 58, arc control 40; with the least amount of spatter. Stick out about 3/4's of an inch.
Hope it helps
Jasigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Originally posted by Glidertow View PostJA, you are on the money. I changed to your settings and all is well, amazing!!
Im glad its working out for you!sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
40 ton press brake
