I own a 35 foot sailboat. I wish to travel abroad carrying my own welding equipment. The boat is made of 1/4 inch thick, 5086 aluminum plates. I have work to do on the boat prior to leaving. The maximum voltage available to me is 230 volts at 60 hertz. Abroad, it would be 220 volts, 50 hertz.I consider purchasing a Millermatic 211 with a spool gun.I am aware of penetration issues for this plate thickness, but I am told proper joints selection preparation and pre-heating would compensate. Is that really so? The Miller chart shows only 4043 feed wire while I would need 5356. Why is that? Their calculator do not recommend globular welding, only spray in flat position(!) at welding voltage in excess of the machine capabilities...Did you ever try welding 1/4 inch 5086 aluminum plates with a Millermatic 211? What settings did you use? How was it?Would you recommend that acquisition for my application?Thanks!
Thick Aluminum - 240 volts - Portable equipment
Originally posted by Doupirate View PostI own a 35 foot sailboat. I wish to travel abroad carrying my own welding equipment. The boat is made of 1/4 inch thick, 5086 aluminum plates. I have work to do on the boat prior to leaving. The maximum voltage available to me is 230 volts at 60 hertz. Abroad, it would be 220 volts, 50 hertz.I consider purchasing a Millermatic 211 with a spool gun.I am aware of penetration issues for this plate thickness, but I am told proper joints selection preparation and pre-heating would compensate. Is that really so? The Miller chart shows only 4043 feed wire while I would need 5356. Why is that? Their calculator do not recommend globular welding, only spray in flat position(!) at welding voltage in excess of the machine capabilities...Did you ever try welding 1/4 inch 5086 aluminum plates with a Millermatic 211? What settings did you use? How was it?Would you recommend that acquisition for my application?Thanks!
in series they make a beautiful 24VDC CV supply... all you need to do is hook up a spoolgun..
way more horsepower than a MM211
Biggest problem might be carrying and refilling your Argon bottle..Last edited by H80N; 04-27-2015, 08:19 PM..
The MM211 won't run the 5 series wire. Cross that one off yer list.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
