Well, you could, I suppose. Have to plug the 10E into a 115Vac receptacle, then adjust its internal contactor control relay so that it merely closes a dry circuit when the gun trigger is depressed( presently would introduce a 115Vac supply) and hook this circuit to the trigger terminal of the autoarc, and flipping its drive rollers open.
Pretty simple for me to do.
Millermatic Auto Arc 130 & Millermatic 10E wre feeder compatibility
Can any one tell me if the gun control plugs are the same, or if they make an adapter? I have a chance to pick up a decent Millermatic 10E wire feeder gor cheap. However, if its too much of a hassle to connect with my Auto ARC, then its not worth the time or the money. It would just be nice to have a second spool of aluminum or heavier gauge wire that's just a connection away from being able to use, without having to switch spools.
Thanks in Advance,
MattTags: None
