Hi All,
First time poster here on the Forum.
I have an Older Syncrowave 250 (Circa 1990 if I recall)
I was doing some welding on an aluminum radiator for my buggy.
Things were going good/ normal for a while, then after a bit I noticed the Arc was having a hard time starting. Got to the point where I was laying into the pedal pretty hard and **** near touching the tungsten to the work piece to get it to start. Once started It does weld. Flipped over to DC- and tried to burn some steel rod.... Same story there, hard to get it started.
High frequency Start is already maxed @ the 100 setting.
Cleaned the points/ gapped to 8 thou, checked ground, torch & collet connections.
Everything looks OK.
I suspect a component malfunction being as this occurred while the machine was in use.
Anyone care to share Any Ideas as to where I should be looking?
As a side note, board was replaced 4 yrs ago and machine doesnt see much use.
Thanks
Thanks
