I have a 2007 xmt 304 that had a help 7. After digging into it found the front igbt and diode to be toast. Everything else checked out ok. All the resistors and caps were good.Ordered a new set of miller igbt's and put in a new diode everything works good but stick mode. When I put it in stick mode I get some high number like 980volts and a squealing noise that gets louder and quitter as you turn the amps up and down. running the machine on single phase 220 volt. Please help not sure where to look now?Thanks.
xmt 304 stick mode problem
On 200 ohms it reads 56.1 Ohms. Thats with the board still connected.Last edited by doubledoor; 04-20-2015, 02:54 PM.
See, help 7 ALWAYS means a drain resistor on the output board is shot, if left too long then an igbt pops along with its protection diode. your problem now is with the front display board as the machine programming resides there, problem is that this board has zero error codes, yet your still getting a help 7. Help 6 is the top board so that's no the issue.
So all the readings I have are good. The drain resistors are good. The diodes are good the gate is good. It's the front board that took out the diode and igbt?Last edited by doubledoor; 04-20-2015, 07:53 PM.
Originally posted by doubledoor View PostSo all the readings I have are good. The drain resistors are good. The diodes are good the gate is good. It's the front board that took out the diode and igbt?
