We have had our Millermatic 180 for about a year now. Used it quite a lot last summer and then haven'd done anything over the winter then this weekend we made a small toe behind yard cart/trailer for the lawn mower and two times during the wire stopped feeding and had fused to the liner right at the beginning to the little spiral spring looking tip just after the tensioner. We had to unplug and pull out some wire then snip it and pull back through then re-feed everything. What are we doing wrong? We have never had an issue all last summer have put maybe two 10 lb spools and 2 or three small ones without issue.
Help - wire fused at liner
My wife has ruined all the corded phones, and numerous 30 foot vacuum hoses. You can get 31 feet out of a 30 foot hose.Dynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
not sure I agree we don't have a cart and it sits on the shop floor next to our work have never needed to "wheel" the cart a little closer with a light tug or been way out of reach that we are pulling on it to get that last weld on. But that doesn't mean the problem isn't fixed the same way. So you are saying I need a new gun not a new liner?
It might just need a new liner- relatively cheap.
My Passport did the same exact thing and I just replaced the liner.
http://store.cyberweld.com/miggunliner.htmlLast edited by Broccoli1; 04-02-2015, 12:00 PM.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
