Montgomery Wards 295 amp AC Welder : Help please
Tags: None
Originally posted by WillieB View PostTwentieth Century & Forney, maybe others use a tapered plug you push in and give a twist. they don't go all the way.
I took a drill bit and wrapped sandpaper around it and cleaned out the corrosion on the male and female connector pins. Didnt seem to make to much of a difference though. They still dont slide all the way in. Im guessing this is normal or the way its suppose to be?
Not a problem
Originally posted by waffenampt View PostI took a drill bit and wrapped sandpaper around it and cleaned out the corrosion on the male and female connector pins. Didnt seem to make to much of a difference though. They still dont slide all the way in. Im guessing this is normal or the way its suppose to be?[ATTACH]35113[/ATTACH]
[QUOTE=Aeronca41;329219]The first welder I bought (new, about 1978 or 79) was the AC-DC version of the one you have-looks identical except for the DC option. I think it was $129 new back then. I've added other welders with bells and whistles since then, but I still have it, and it still works like new. Plugs never went all the way in. Just twist them in as far as they go and weld.[/QUOT
Thanks for the reply! much help! Thank you!
I have that exact welder.. been in use for over 35 years without a hic-cup. As posted above, there is a taper in the design of the socket such that as you push the tip in and turn it slightly, it makes for a tight secure connection.
Attached FilesLast edited by dandeman; 04-01-2015, 08:54 AM.Hobby Welder for about 32 years
Hobart 190 MIG with SpoolGun
Hobart AirForce 700i Plasma Cutter
Hornell Speedglas 9000X Helmet
295A AC Buzzbox (what I learned on)
Miller Bobcat 225, factory propane option, also serves as my emergency power generator
Dandeman's Toy Page
As time goes on they wear a bit, you clean them with scotch brite, or a fitting brush on the female, they go in farther.Dynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
