While fillet welding 18 gauge to 1/8' steel , I am getting a yellow flashing , that is too bright to see the weld . Material is 18 cold rolled to 1/8 hot rolled . Hot rolled was sanded and wiped with non chlorinated brake cleaner . The welder is a 300 Dynasty DX with knobs . Gas flow at 17.5 CFM . I have seen this occasionally before , but this piece seems to be unweldable .
help needed again
CFM vs CFH
Originally posted by Milton View PostWhile fillet welding 18 gauge to 1/8' steel , I am getting a yellow flashing , that is too bright to see the weld . Material is 18 cold rolled to 1/8 hot rolled . Hot rolled was sanded and wiped with non chlorinated brake cleaner . The welder is a 300 Dynasty DX with knobs . Gas flow at 17.5 CFM . I have seen this occasionally before , but this piece seems to be unweldable .
what brand and model helmet...?? might need new batteries..
BTW... Argon flow would be in CFH (Cubic Feet per Hour)... 17.5 CFM would be a hurricane at the torch... and you would be trading gas bottles a couple times an hour...
Originally posted by Milton View PostHelmet is a Hobart 770098 . I am guessing 10 years old . Never had a new battery .
Am betting it takes a pair of Panasonic CR2450 button cells..
http://store.cyberweld.com/reliba.html
Here is a thread on helmet batts.. and probs
http://www.millerwelds.com/resources...ghlight=CR2450
Originally posted by Milton View PostDoes anyone have experience replacing the battery or batteries in the Hobart 770098 helmet . It appears to be a sealed unit .
the battery tray is not readily apparent the Hobart may be similar..Last edited by H80N; 04-02-2015, 06:54 PM..
Originally posted by Milton View PostJust checked again , no sign of a drawer , a two piece case , snapped together or glued .
is it one of these?? have been unable to cross it by the "770098" number
http://www.hobartwelders.com/om/6digit/o261661b_hob.pdf
http://www.hobartwelders.com/om/6digit/o245869f_hob.pdf
http://www.hobartwelders.com/om/6digit/o257076c_hob.pdf
They all seem to use just one battery that is behind a threaded door..
like a miniature manhole cover..
There are more manuals here
http://www.hobartwelders.com/service/owners-manuals/.
