30a spoolgun to lincoln 210mp is it possible?
  • cruizer
    Ok, not possible, unlike its larger cousin, this one uses the 100sg magnum. If the machine didn't have to control the wire speed, the connections would have been simple enough
  • Tryagn5
    Originally posted by cruizer View Post
    Well no cable needed nor a we-24, you merely cut the 10 pin off, solder the existing wires on the new 16 P amphenol and plug it into the 210's spool gun connector
    That said I haven't seen the service manual on the Lincoln. Pretty sure there is the 7 pin. You can make a 10 to 7 pin adaptor if you intend on moving the spool gun around.
    I will check sunday to see if it has the 7 pin. Also do u sell the 10 to 7 pin adaptor?
    kevin
  • cruizer
  • Tryagn5
    Easy, think it's a 16 series 7 pin clocked to W, which you will need
    Where would i get this cable? Also will a wc24 be needed?
    kevin
  • cruizer
  • Tryagn5
    started a topic 30a spoolgun to lincoln 210mp is it possible?
    Just picked up my mp210 is it possible to hook the 30a to it
    ? Going to be reducing my welding equipment as i have spent the last 2 years being an employee vs a employer.
    Kevin
