30a spoolgun to lincoln 210mp is it possible?
  • 30a spoolgun to lincoln 210mp is it possible?
    Just picked up my mp210 is it possible to hook the 30a to it
    ? Going to be reducing my welding equipment as i have spent the last 2 years being an employee vs a employer.
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
    Easy, think it's a 16 series 7 pin clocked to W, which you will need
      Where would i get this cable? Also will a wc24 be needed?
      Thanks
      kevin
      Ln25
      Miller spectrum 625
      Miller 30a spoolgun
      Wc115a
      Lincoln 210mp
        Well no cable needed nor a we-24, you merely cut the 10 pin off, solder the existing wires on the new 16 P amphenol and plug it into the 210's spool gun connector
        That said I haven't seen the service manual on the Lincoln. Pretty sure there is the 7 pin. You can make a 10 to 7 pin adaptor if you intend on moving the spool gun around.
          I will check sunday to see if it has the 7 pin. Also do u sell the 10 to 7 pin adaptor?
          Thanks
          kevin
          Ln25
          Miller spectrum 625
          Miller 30a spoolgun
          Wc115a
          Lincoln 210mp
            Ok, not possible, unlike its larger cousin, this one uses the 100sg magnum. If the machine didn't have to control the wire speed, the connections would have been simple enough
