Hi, I am new to the site and also to welding. I have a question about which type of gas to use with different materials. How do you know which type of gas to use with a specific metal? Such as stainless steel, or regular steel, and so on? Does it just take experience working with those types of metals that you eventually learn what goes with what? I am confused by this. Thanks a lot and I hope to here from some of you..
Which type of gas to use? Beginner.
Originally posted by Baktc88 View PostHi, I am new to the site and also to welding. I have a question about which type of gas to use with different materials. How do you know which type of gas to use with a specific metal? Such as stainless steel, or regular steel, and so on? Does it just take experience working with those types of metals that you eventually learn what goes with what? I am confused by this. Thanks a lot and I hope to here from some of you..
will explain the why's and wherefores of gas selection...
here is the link to download the PDF..
http://www.prest-o-sales.com/other_l...n%20Manual.pdf.
Reading the Praxair guide can be like drinking from a fire hose. Also, their proprietary shielding gas names and mixtures can be confusing at first.
Here's another, more basic discussion with a simplified shielding gas chart that might get you going faster:
http://www.lincolnelectric.com/en-us...c-welding.aspx
Across the top of the table are the welding processes and the column on the left are the common materials.
HTH,
Mike
Too Simple to be useful...
Originally posted by SdAufKla View PostReading the Praxair guide can be like drinking from a fire hose. Also, their proprietary shielding gas names and mixtures can be confusing at first.
HTH,
Mike
that chart loses the "WHY" as to the use of the various gasses and mixes...
it is very useful for the weldor to understand at least a little of the physics of the interaction between gas and metals being welded..
Keep a copy of the manual for reference... no need to swallow all of it in one sitting... that is part of the beauty of having free PDF technical downloads..
AND...
as far as tradenames... it seems that the suppliers like the confusion for marketing purposes...
However... simple solution is yet another Free PDF download... "Cross Reference"....
http://www.aoc.com.mx/biblioteca/tab...PROTECCION.pdf
that should remove a lot of the mystery....
Just give him the dam answers to his questions
Mig welding.>>
Stainless steel uses trimix gas.
Aluminum uses argon. And
Mild steel uses 75/25 argon co2 mix. .
On aluminum dont forget to swap your polarity
Tig all straight argon. 100%.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Originally posted by eecervantes83 View PostJust give him the dam answers to his questions
Mig welding.>>
too bad the real one is not always that straightforward....
Mig welding.>>
Im I missing something? swap your polarity for aluminum? Did you mean flux core wire?sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Originally posted by ja baudin View PostIm I missing something? swap your polarity for aluminum? Did you mean flux core wire?
maybe his world is flipped .....
Originally posted by H80N View PostSometimes "simplified" removes the meaning of the lesson...
AND...
Yea I would like to know why which gas works best with which material and understanding why it is that way! I will download both PDF's! Thanks for the help!
Just Curious...
is
"Baktc" for "Back to Sea".......
Thanks Ja for the correction..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
