My welder requires 230V AC and 50 Amps. It is a inverter based welder and uses a NEMA 6-50p plug (pic attached).
Looking to wire the 240V to my garage and making sure I have the configuration right. The two flat blades are separate 'hot' wires from the panel and the third plus is 'ground', correct?
When measuring after install, I should get 120V from ground to each of the hot wires and 240V between the two blades, correct?
Just making sure I remembered my electrical theory correct...:-)
Thanks.
Thanks.
