Whats the cost per inch on steel irrigation pipe . And whats your guys procedure. Im talking about 36" diameter size. cut and weld with band straps over the cut seams.
cost per inch.
cost per inch.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#Tags: None
How much to weld ..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
I know there's a set price per inch but I cant seen to find it nowhere online..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
Originally posted by eecervantes83 View PostI know there's a set price per inch but I cant seen to find it nowhere online.
each weldor has a different style.. speed.. consumables use... overhead etc..(gotta figure in rent... insurance and equipment cost..)
so it would be impossible to impose one number to it...
but you can run some test pieces.. and calculate YOUR cost per inch for this instance...Last edited by H80N; 03-22-2015, 11:53 AM..
The only time I have heard the term cost per inch for welding is from someone who has never been a professional welder.
Did you go look at the job - Thats a cost.
How much travel time will you have.
How much set up time will you have.
How much cleaning is required.
How long will it take to weld.
All of these things are a cost.
So figure out how much time you will have into it and then figure out how much you want to make per hour.
I just had to go work on a vacum chamber that cost around a half million, they paid me for 6 hrs of drive time, 1 hr to get in, 1 hr to get out, 1 hr to weld and zyglo test it under vacum and 45 minutes to wrap up.
9.75 hrs over time to weld about 1-1/2" max. well over a $ 1,000.00
