Hi My name is Kris. I'm new to this forum. I have a small home business where I make parts and sell. Lately I designed new product which requires aluminum to aluminum joint. I do not own a welding machine and the parts I want to join require only small short welds. How much of pulling force the weld can withstand? Part will be mounted to the bench and pulled with force of at least 100lbs. I attached a drawing which shows the pulling force direction. Do you guys think this will hold? Thanks
Aluminum brazing rod joint strength
Originally posted by Kristof View PostHi My name is Kris. I'm new to this forum. I have a small home business where I make parts and sell. Lately I designed new product which requires aluminum to aluminum joint. I do not own a welding machine and the parts I want to join require only small short welds. How much of pulling force the weld can withstand? Part will be mounted to the bench and pulled with force of at least 100lbs. I attached a drawing which shows the pulling force direction. Do you guys think this will hold? Thanks
Aluminum brazing rod?? is a broad definition which one and what exactly are you joining..??
if you are talking about those flea market/state fair propane-bernzomatic rods .. they are largely junk..
You might consider subcontracting out the welding to somebody else and have a sound weld.
Originally posted by Kristof View PostYes. I'm talking about the bernzomatic rods.
Here is a drawing of where I need to weld the pieces together.
[ATTACH]35073[/ATTACH]
probably TIG if it is a small part..
those brazing alloys need a lap joint with lots of surface area to achieve their ideal strength and durability... your application does not provide that...
Griff
I asked about these products not long ago and got lots of good observations. Go to page 4 and click on SWAP-MEET ALUMINUM BRAZING ROD.
Meanwhile, I agree with H80N that the type of joint you show is quite unlikely to get good results when "welded" with the low-temperature rod. That type of rod does have some limited uses, but not to include what you are doing, I don't think.
If the maker of the rod states that the fluxes in his product allow you to make good welds without any pre-weld cleaning of the joint, don't accept that. Aluminum is rather tedious to work with, in that it needs to be carefully cleaned and prepped right before any welding is done.Last edited by old jupiter; 03-19-2015, 11:21 PM.
