My miller 180SD is giving me **** right now. Just last week all my weld were nice and shiny but yesterday everything turn to ****. I couldn't even get an arc started on AC or DC. I triple check all my settings. But all im getting is yellow and black smoke my
tungsten also melt and crack. I changed out my argon tank,tungsten,gas lens, setting. nothing work! please help.
Syncrowave 180sd having major problem NEED HELP!!! PIC INSIDE
Originally posted by supraling View PostMy miller 180SD is giving me **** right now. Just last week all my weld were nice and shiny but yesterday everything turn to ****. I couldn't even get an arc started on AC or DC. I triple check all my settings. But all im getting is yellow and black smoke my[ATTACH]35063[/ATTACH][ATTACH]35064[/ATTACH][ATTACH]35065[/ATTACH] tungsten also melt and crack. I changed out my argon tank,tungsten,gas lens, setting. nothing work! please help.
are you sure you have 100% ARGON..??.
Originally posted by supraling View Postyes this is my 2nd tank it fresh just went and bought it today.
Originally posted by supraling View Postyes i understand but my 250 bottle were fine last week but then yesterday i was having problem so today i went and got anther tank. so i dont think it the gas.
How about TUNGSTEN...??
any chance you got some gypsy chinese BrandX electrodes..??
chinese collets...??
cracked backcap..??Last edited by H80N; 03-18-2015, 07:16 PM..
Gee a serial number sure would be nice, just to see which model this is out of many 180sd units. Anyhow, does it seem to want to run at full tilt?
Does seem to be bad or inconsistent gas, almost looks like atmospheric, getting into your torch, maybe a hole in the hose. Seems fishy to change your bottle out though
I just went outside to swap a new regulator and lines. Pressure tested my Number #17 torch and lines, regap the spark to .010 then went back to my old tank which proven to be a good gas since i weld with it before.
I have a better chance to start an arc WITHOUT GAS and it does seem like it want to go full tilt. But I always end up melting and balling my tungsten in just a few seconds all my tungsten are weld craft 3/32 green, red and light blue.
The serial number is LE228931
I attached some more pictures using the same test piece as before.
Originally posted by cruizer View PostSee a serial tells me that the hall device inside your machine is pooched and requires replacement.Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
BFH
Originally posted by Silverback View PostHow do you know that from the serial? Is there an easy way to look it up? (another 180sd owner)
Originally posted by supraling View PostIs it common for this model of syncrowave to have a faulty hall sensor? According to the timer it only has 1:48min and 37 cyclesIs this the hall sensor you are talking about?[ATTACH]35071[/ATTACH][ATTACH]35072[/ATTACH]
How can i test to see if the hall sensor is bad?
I been messing with it for a bit I struck an arc in stick mode on DCEN for about 10sec it melted my cup! I change out the cup and eletrode then try it on AC
it work! I was able to start an arc and kept it going but i still have some contaminate. Not sure what made it better, turning up the heat up in my garage or my torch is mess up some how?
