Airco Wasp II-E stock # 1350-0039
purchaced from Hudson Valley welding supply
I have an Airco 11-E stick generator welder, worked great for years but now little or no arc . powered by a 12 hp kohler engine which works fine but I do have a linkage problem as it wants to run at High rpm /. I have been told that it might not weld it a 12volt battery is not connected all the time but that does not seem right I have changed fuses on the board but still nothing . Can it be that it is running too fast ? wish
I could find a repair manuel that would help . this welder has always been kept inside
