problems with miller 35
  • problems with miller 35
    my feed motor does not work, replaced cr-2 did not fix problem. help!!!
    Could you provide the serial number so I get the right print pulled up?
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
      mm 35 feed problem
      the ser, no- jd686965
        I would start by looking at CR-1 and the main contactor to make sure they are both pulling in when you pull the trigger. if they are I would suggest checking the AC volts going into SR-2 when you have the trigger pulled. Depending on what tap you have the unit set on that voltage should be between 8.5 and 18.5 roughly. If you have voltage there then I would look for DC volts across leads 46 and 50 at the SR-2 again this is with the trigger pulled.
        This is just a start let me know what you find and we can work from there.
        [email protected]
        Ph: 920-735-4505
        Kevin Schuh
        Service Technician
          [email protected]
          Ph: 920-735-4505
          thanks very much!!! I will get back to you.
