mm35 wirefeed problems
  • cruizer
    Sorry thinking of new machines not real old ones, do you have a skp panel?
    if not, might want to check/ replace control relay cr1
  • hot ticket
    mm 35 feed problem
    did not think of that, thanks for your help.
  • hot ticket
    mm-35
    Originally posted by cruizer View Post
    did ya check the fuse on the cct board and make sure your not inbetween ranges
    this model does not have cct board, that I could see. thanks for your help.
  • walker
    I would jumper the trigger wires before anything else, just because it is easy and a common problem.
  • cruizer
  • hot ticket
    started a topic mm35 wirefeed problems
    I bought a miller 35 a week ago, it worked at the sellers home. I live in the desert area, so I put on a military trailer to bring it home on some bad roads. it worked one time only when I got it home, but not now. every thing seems to work except the feed motor. I checked all connections. found that cr-2 looked bad so I replaced it, still does not work. help!!!!
