mm35 wirefeed problems
  • mm35 wirefeed problems
    I bought a miller 35 a week ago, it worked at the sellers home. I live in the desert area, so I put on a military trailer to bring it home on some bad roads. it worked one time only when I got it home, but not now. every thing seems to work except the feed motor. I checked all connections. found that cr-2 looked bad so I replaced it, still does not work. help!!!!
    did ya check the fuse on the cct board and make sure your not inbetween ranges
      I would jumper the trigger wires before anything else, just because it is easy and a common problem.
        mm-35
        this model does not have cct board, that I could see. thanks for your help.
          mm 35 feed problem
          did not think of that, thanks for your help.
            Sorry thinking of new machines not real old ones, do you have a skp panel?
            if not, might want to check/ replace control relay cr1
