Is anyone familiar with shielding gas filters? I'm trying to find in-line type filters that I can hook up once the gas has passed through the regulator. I'm finding very fine filters, like .02 or .01 micron, but I feel that is a bit excess for my requirement. In reality, I'd like to find one filter around 60-80 micron and another between 5-10 micron. Brass material is preferred. Does anyone have any suggestions on types of filters or at least where I can look to find some filters?
Shielding Gas Filters
Originally posted by ksm2 View PostIs anyone familiar with shielding gas filters? I'm trying to find in-line type filters that I can hook up once the gas has passed through the regulator. I'm finding very fine filters, like .02 or .01 micron, but I feel that is a bit excess for my requirement. In reality, I'd like to find one filter around 60-80 micron and another between 5-10 micron. Brass material is preferred. Does anyone have any suggestions on types of filters or at least where I can look to find some filters?
Which process are you working with?
RichardRichard
West coast of Florida
Originally posted by ksm2 View PostIt is a requirement of a code that I work to. It would be used on shielding/ trailing/ purging gas for TIG and FCAW processes.Richard
Swagelok makes several filters in both brass and stainless.
http://www.swagelok.com/search/find_...d-48b40f5dce08
Here are 2 home made trailing shields.
Tubing is 1/4" OD and uses 100 mesh stainless screen.Attached FilesMiller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
Originally posted by ksm2 View PostThank you for the help! I was able to find a brass filter in my continued research, but I just realized I'm also in need of a fiber filter which I have yet to see any of this style filter. Any suggestions?
Have you considered using a clear inline fiber fuel filter like a FRAM G3HC..??
should be well within the working pressure range for argon...
http://www.amazon.com/Fram-Universal.../dp/B00QR7MJU4Attached Files.
That sounds like a smart idea! Good thinking on that one H8ONsigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
