I picked one of these welders up last Sunday. Got everything cleaned up and wired in. Was able to get a nice weld in AC/DC-/DC+. The caps for the HF section have oozed out, so I've got replacements ordered for that. I don't believe the HF works as it should be. (I did set the arc gap though) Anyhow, I'm setting this unit up as a workhorse for everything around the house/shop. I have a TIG torch setup on the way as well as a regulator. Going tomorrow to look at/buy a cooler setup for it as well.
Anyhow, I'm sure I can get the HF stuff sorted. The torch I bought has a switch on it as well. But my real question is, can a pedal be retrofitted into these units? I see the Miller RFC-23A is the pedal of choice for the Dialarc 250. Which from what I've gathered, this Airco model is the predecessor to it. But I know there's no provision for remote current controls on this unit. (Just the HF control) Is there a means of adding it to this welder? Or has anyone split up the internal wiring to feed 110V to the HF side and Low voltage to the gas solenoid. (Alternatively, I could swap out the solenoid to a 110vac I guess) I've been reading about SSVR's which I could use a 10K foot pedal to control and vary input voltage to the transformer that way. But I'd be more interested in constructing something "factory" for it.
