Do I need a different gas regulator when using straight C02?
  • Do I need a different gas regulator when using straight C02?
    Have the Horbat Ironman 230 welder, it came with argon mix regulator/flow gauge.
    Do I really need a different regulator to use straight C02 gas?
    If I do any recommendations as to which one to purchase?
    The stems are very different... so must have a different REG or adapter nipple..
    A CO2 bottle has a flat surface on the valve.... so the regulator has a flat surface and hard plastic or teflon gasket as in this pic
      I recently talked to a guy that owns and runs a regulator rebuild shop. I specifically asked him if there was any reason to have a different reg/flow control for C02 for mig welding. He said not that he could think of. That's for MIG only now.. He said maybe dual stage to split the expansion ratio a tiny bit but all the sets he puts together for mig are all standard sets other than the mating fittings. If you want to use the C02 for high flow systems then there may be an issue.
        The Mating Fittings Are The Issue..
        The Major issue is that an Argon Regulator WILL NOT CONNECT to a CO2 bottle without changing out the nipple or putting an adapter between...
        They are different..
        Another issue is Regulator Freezing at higher flow rates
        Some of the dedicated CO2 regulators are finned or heated to deal with this problem..
        Like this Harris 6CD
        The page you are looking for is no longer available or has moved. Please visit the site map for a list of pages currently available on this site.
          http://www.harrisproductsgroup.com/e...Model-6CD.aspx
          The CGA (type of tank fitting) isn't really a fixed part of the regulator. Sure C02's are generally CGA320's with a face washer, but that's just the fitting. The regulator and gauges are the same.
            And your point is..??
            That does not negate the fact that
            Before using an Argon/Oxy regulator for CO2
            You still need to either alter it by changing out to a CO2 style nipple or add an inline adapter
              Should have listened to HN! The guy knows his stuff.
              Yes the cheap azz stock flow meter will work, but it's not going to fit on the CO2 bottle. That adaptor or nipple is rather $. Best to get a clone flow meter for CO2, mostly cause the CO2 tends to freeze the 2 stage regulator.
                Point is, the input nipple doesn't dictate the type and/or function of the regulator. For mig and tig, it's all in the body of the regulator and the orifice.
                  Yeh, a shop that's been in business for two generations wouldn't know anything I'm sure.
                    Maybe you might go back to that shop and doublecheck your assertions..??
                      Consider too the different densities of the gasses. Flowmeters are calibrated for the specific gas service, but for most applications, 99% of the time the difference is negligible. However, if you are working off a WPS this would matter.
                        A high pressure Argon flow meter will work with CO2, after all cfm is cfm on any bottled gas. However, a low pressure CO2 meter will not work with high pressure Argon.
                        Because the bottles have different pressures, the bottle outputs are different. Kinda get it now....
                          By calibrated I mean each gas has a different density in atmosphere. That determines how much gas it takes to move the ball or needle on a given regulator. CO2 is 'heavier' than Argon, so you can imagine it changes the way it moves the needle or ball. Like I said, the difference may only be 10% either way between the gasses and for most of us it's no big deal.
                            Thinkin that Argon is heavier than Co2
                              You need an adapter
                              and the Nylon/plastic washer that is pictured in H80N's post.
                              Ed Conley
                              MM252
                              MM211
                              Passport Plus w/Spool Gun
                              TA185
                              Miller 125c Plasma 120v
                              O/A set
                              SO 2020 Bender
                              You can call me Bacchus
