So it's my understanding that if you set the Weld Process Selector switch to -Tig. And the Coarse Range Switch to(say)40-100 amps(3/32). Then the Fine Control switch(whatever is best)say 6. With the Pos. lead going to your Tig/gas. And the Neg. to your material, then you should be able to Tig small-med. metals, such as tabs to a motorcycle frame? Or is this not correct? Thanks for any and all help.
Tig welding w/Bobcat 250
Originally posted by harleyjo View PostSo it's my understanding that if you set the Weld Process Selector switch to -Tig. And the Coarse Range Switch to(say)40-100 amps(3/32). Then the Fine Control switch(whatever is best)say 6. With the Pos. lead going to your Tig/gas. And the Neg. to your material, then you should be able to Tig small-med. metals, such as tabs to a motorcycle frame? Or is this not correct? Thanks for any and all help.
you want your TIG Torch Negative and the work/ground lead Positive...
TIG for steel is DCEN...
and amperage set to about one amp per thousandth thickness to start out and adjust from there...
probably want to set your Argon flow to somewhere between 15 to 18 CFH (cubic feet per hour)Last edited by H80N; 03-02-2015, 05:08 PM..
10-4, That's what thought. But directions in manual not so clear on settings. I do remember that on my 64' pipeliner i had to switch them over. Man that thing would weld, and easy to work-on. Thanks again for the help and quick reply. Now for those who don't understand, has this to look at. JIM[SIGPIC][SIGPIC]
The Older I Get, The Better I Was.
CPW Retired
Griff
Originally posted by harleyjo View PostSo it's my understanding that if you set the Weld Process Selector switch to -Tig. And the Coarse Range Switch to(say)40-100 amps(3/32). Then the Fine Control switch(whatever is best)say 6. With the Pos. lead going to your Tig/gas. And the Neg. to your material, then you should be able to Tig small-med. metals, such as tabs to a motorcycle frame? Or is this not correct? Thanks for any and all help.Lincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
scratch starting, was also wondering about how thin i can go(heat wise on settings). Maybe exhaust pipe for m/c's ? I've always got my mig(Lincoln 140+ w/spool gun) and .024 wire. As soon as weather clears will try various thicknesses With Tig, and going to try stainless, Mig works great for aluminum, but will be doing alot of stainless(flatstock tabs, stainless to carbon filler wire(what do i need? Txs for all the help so far. Jim[SIGPIC][SIGPIC]
CPW Retired
I have the same mig box you have and it does super with .23 stainlees wire you might wanna just forget the tig and use the mig for the stainless. I have the spoolgun setup on mine too it does nice work on 1/8th aluminum and I also have used it in the past to weld a/c coils that have leaks .my buddy couldn't believe how I was welding them coils with a spoolgun .
