Trailblazer 325 questions and need feedback
  • MAC702
    Originally posted by RRFab View Post
    I know this is an old thread but maybe some one will still see it. I know that the lincoln 305 had over fueling issue does the miller 325 share this issue or will I be ok with the self shut off at the pump?...
    This is a specific question that needs its own thread with the specific issue in the subject line.
    This sounds like a fuel filler neck orientation issue, combined with the particular fuel pumps being used. Some may not have a functioning auto-off if your fuel filler neck is vertical. You'll learn soon enough where to get fuel if you can't do it manually.
  • RRFab
    I know this is an old tread but maybe some one will still see it. I know that the lincoln 305 had over fueling issue does the miller 325 share this issue or will I be ok with the self shut off at the pump?
    Thank you in advance
  • jbomb
    What about the 325 Diesel, anyone try one. I know the ranger 305 were troublesome.
  • nfinch86
    Fine Control
    Originally posted by cruizer View Post
    But BJ is right fine control does adjust the aux on a R8. I rarely see one, so going off my brain doesn't help sometimes.
    Yep, That's what it was cruiser, I put the fine control up to 10.
    Now my vac. output is running at 124vac. !
    In the Spring I'll take the cover off & clean the slip rings.
    Yep, you don't see a lot of them around any more. I bought it three yrs. ago ( it's a 1995 ) with only 55 hrs. on it . The guy had it sitting in a cargo container as a backup generator.
    Thanks guys;
    Norm
  • sjohn
    ohh I forgot to add its a 2013-2014 model only thing wrong he saids small dent in the back..otherwise runs and welds good
  • sjohn
    hello
    well sorry I didn't get back to ya'll anyways i'am trying to make a deal for a used Miller trailblazer 302 welder with 181 hours on it NO cables with unit.
    So I will see how this goes! from what the sellers saids oil,filter,spark plugs been change. however the hz have never been checked.
    So will see what happens there
  • cruizer
  • nfinch86
    Remove your covers to get access to the 2 sliprings. If they are really black or any colour but kinda brassy, then spray them down with brake clean and with a fine Emory also soaked in brake clean, start the engine up and with the Emory swish back and forth till the rings are a bright brass
    Thanks Cruizer;
    I'll do that in the morning !
    Norm
  • bjfab
    On a Ranger 8 voltage changes with the fine output setting
    Byron
  • cruizer
  • nfinch86
    Won't affect much though the likes of a 305 g is running 118 - 125 vac at 62.5 hz, yours could also be a dirty slip ring issue
    Thanks Cruizer;
    What's the best way to correct that ?
    Norm
  • cruizer
  • nfinch86
    120 volts ?
    Originally posted by nfinch86 View Post
    Sorry, My Bad .
    I mean Hz. has been reset to the correct frequency - 62.5 Hz....... Lol .
    The above post has been corrected !
    Norm
    One thing I noticed since adjusting the Hz. to 62.5 , is that I just checked the AC. output and now it's just putting out 108 volts @ the receptacles Not 120 volts .
    Any concern for worry, will 108 volts cause problems running my tools ?
    Norm
  • nfinch86
    Hz !!!!!!!!!!
    Sorry, My Bad .
    Norm
  • Cgotto6
    Originally posted by sjohn View Post
    with a frequency meter like this one:
    one of buttons is hz..so just plug into outlet and press the hz button I run one on my generators now to make sure its right
    sjohn;
    Well I ordered the KILL A WATT monitor & come to find my Lincoln Ranger has been running at 70.5 Kw. not 62.5 Kw. for the last 3 years !
    Well I corrected it today , it's now at 62.5 Kw. , so I'll have to see if I find any difference in performance. It's for sure a lower RPM. now !
    Also at idle it's now at 38 Kw. , well time will tell, I guess .
    Norm
    kW is a measurement of energy, not frequency. You probably are reading in hz.
