Miller trailblazer 280nt
All the wires and plugs check out ok. There is a diode, GT60-04f in line. I have checked that and it seems to be bad. Could this be all that causing it to not start?
It does start and run if I jump the starter. Next I guess is to look for broken wires?
Originally posted by bulldog77 View PostThe starter, switch, and regulator all have been replaced. 12.86 volts from battery and I also have switched out batteries.
Clearly your wiring from the igntion switch to the starter solenoid...ie the little wire which engages the starter solenoid coil is bad or is nearly broken. Test the wire for voltage with it hooked to the solenoid, and unhooked. If you get voltage with it unhooked then the wire is nearly broke or there is heavy corrision in the plug. Have you tried jumping the solenoid to see if it starts?
Kevin
Originally posted by Tryagn5 View PostOk i assummed you changed the battery. So change the battery if the unit only starts when it is jumped then clearly the battery is bad. You had previously stated it does nothing. Gotta figure if you did a starter you would also have checked for a charged battery. Now check the charging circiut. With the engine running you should have around 14 volts at the battery.
Kevin
Even if it seems to be charging to a nominal 13.8 volts while running .... it will drain the battery flat a few hours after being turned off..
power on side of starter..
Also how much power to one side of starter..actual voltage...not a test light. If you have good voltage ie..11.5 or more when the unit is turned to the crank side you should see the same voltage to starter circuit solenoid wire..if not bad wiring or bad switch or discharged battery
Kevin
Originally posted by bulldog77 View PostI have checked continuity on all the wires from the switch to plug to switch and all tested good. The guys tell me they had to jump start it most of the summer. The minute you took the jumper cables off it would die.
Kevin
Originally posted by H80N View PostAmong other things that can be damaged or destroyed by jump starting a Trailblazer is the monolithic voltage regulator on the engine.. they are potted and therefore not repairable... so must be replaced when damaged by the huge current inrush when jump starting..
Pic below
Pic belowAttached Files
Originally posted by Tryagn5 View Posthopefully you did not burn up the board by jump starting it. Trailblazers can not be jump started or boost started. It frys the control board. Cruizer can tell you which one it smokes. As for the starting issue. Likely the plug between firewall and engine connector or bad igntion switch. Ohm starter wire off the igntion switch to the starter solenoid motor on the engine.
kevin
jump starting...
Originally posted by bulldog77 View PostWe have a trailblazer 280nt with a onan engine on one of our tool trucks. For awhile it could only be started if it was jumped and you left the cables on between the truck and welder. Now it came in and it wont crank over at all. We have replaced the starter, switch, and voltage regulator. We have power to one side of the starter but nothing after that. Any direction would be appreciated.
kevin
We have a trailblazer 280nt with a onan engine on one of our tool trucks. For awhile it could only be started if it was jumped and you left the cables on between the truck and welder. Now it came in and it wont crank over at all. We have replaced the starter, switch, and voltage regulator. We have power to one side of the starter but nothing after that. Any direction would be appreciated.Tags: None
