bobcat 225 vs bobcat 250
  • bobcat 225 vs bobcat 250
    Hello I'm new into the engine drive welders and I have been looking into the bobcat line I have a budget of $4200 just wondering is there a huge difference between the 225 and the 250 is it worth the extra money to get the 250 I plan on using it for fabrication some structural and a lot of repairs on heavy equipment and input would be appreciated thanks in advance
    yes I would like to know that to! I can buy a use 1999 bobocat 225 with only 1.5 hours on it. cheaper then a new 250 model
      A bobcat 225 is a little small on the heavy repair side. Fine for stick welding...however some bobcats struggle to run bigger wire or air arc. If i had a budget of 4200...i would save my money and buy a lincoln ranger 305g. I used to run tb302's and tb275....until i used a 305g. 305g is a better welder. As for the tb325s...to many issues, give them another year and i would consider one.
      kevin
      Lincoln ranger 305g x2
      Ln25
      Miller spectrum 625
      Miller 30a spoolgun
      Wc115a
      Lincoln 210mp
      F550 imt service truck
        kevin
        good to know..thanks! when you say bigger wire you mean the welding leads?
        thanks
          No he is talking about running a larger wire through a feeder that's hooked to the bobcat.
            ahhh ok thanks
