Hello fellow welders-
Next week my time is up, to face the music on an AWS 1/8th Titanium butt weld for cert. Not allowed any gap what so ever, straight up flush butt weld. **** you AWS, your Monsters!!
I'm pretty much getting sporadic results on my test pieces. It's such a fine line of reading the puddle vs. excessive penetration root side.
Looking to achieve a 3/1 ratio as in (3)face vs (1)root penetration ultimately.
Have my purge box, face protected by trailing cup extension, garbage.
Amperage- Rule is 1amp per thousandth, 1/8th =.125 hence an immediate 125 amp. I'm feeling that just wont cut it. I know with stainless 316 it requires 10% bump (12.5). Which puts us at 137.5 amp. Though titanium (Grade 2) seems to require more. Or compensate via travel speed, i dunno yet, quite honestly..
I start, load up with rod to build a readable puddle. Not much to read into Ti though, (no cats eyes etc), i was taught wait till puddle is truly clear, mirror like, then you know your getting pen. Past milky/foggy puddle, to true mirror quality. Well by then am I pushing it too much? Was told, clear means add an move, ie: fill and get off quickly.
I place purge fixture on 45% angle towards me, so i can see what puddle trail is doing. Puddle shimmer means drop through to me. Am I looking for light, med, or heavy shimmer?
Noticed face usually sits flush with mild rod dips. No, concavity issues up top. Yet trying to read and use gravity to my advantage at same time.
Its literally driving me BATS!! Have to get this dialed in.
Any help greatly appreciated!!
Pleeeeease Help!!
Thanks!!
gg
Pleeeeease Help!!
Thanks!!
gg
