Bernard Q150 mig gun for the miller 211
  • Bernard Q150 mig gun for the miller 211
    I am going to get a replacement mig gun for my 211, I like the bernard line of guns. In perticular the q150 that comes standard on the miller multimatic 200.
    has anyone here upgraded their gun on the smaller millermatic line of machines?
    I can order a 10' 12' and a 15' I like the idea of the 15' whip but not sure if that little drive motor can handle it. I'm confident the 12' would be fine.
    weldfabulous.com has the Q1512aa8bm for 170.00.
    If someone can convince me that they have successfully used a 15' whip on this size machine, I will go ahead and get that length. otherwise the 12' will have to do.
    MM 211 W/ Spoolgun
    Diversion 180
    Spectrum 375 X-TREME
    Portable Victor O/A
    Palmgren Bench Drill Press
    14" Evolution Dry Saw
    IR 60 Gal. 3 HP Compressor
    Speedglas 9100x
    My Brain
    10' is the only recommended gun lead. Anything longer supposedly burns up the little drive motor.
      Yes, For years I used a 15ft. mig gun on my Lincoln PM. 180, with " No Problems " at all !
      Norm
        My weld supply told me quite a few folks did this. The motors don't burn out immediately, aren't that hard to change or very expensive. 10 feet just is NOT enough.
        Miller 211 AutoSet
        Miller Dynasty 200 DX
        Thermal Dynamics Cutmaster 42
        "The Sleep of Reason Produces Monsters"
        Francisco Goya
          I'd say, put a 20 footer on, burn the drive up, after all it'll be a tech to replace it. Motor is expensive, and so are we?
            Not Immediately... BUT....
            Motor $82.15 plus shipping from Miller4Less
            Having a Tech install it... probably another $100...
            Sounds like it rounds out to about $200
            The logic that would drive this decision..?? PRICELESS..
            Thiis is a hobby grade machine... might as well accept it's limitations or bite the bullet move up to an industrial grade..
              I think I'll pass on the 20 footer, although that would be sweet. I do worry about the longevity of the drive motor with the 15' gun.
              I'm going to get the 12' today.
              I am just a hobby welder, so I may use 5 lbs of wire a year. I'm confident the drive motor will last pushing 2 extra feet with as little as I use the machine
              I'll post when I have a chance to use it and give you my thoughts.
              BTW weld fabulous.com is one and the same with Mississippi welders supply for you upper midwesterners.
              MM 211 W/ Spoolgun
              Diversion 180
              Portable Victor O/A
              Speedglas 9100x
              My Brain
                Benny,
                Whenever I get this question my suggestion is to use no longer than a 12' gun.
                I have talked with a number of people over the years that run 15' guns on the small units and in most cases they have no feeding issues. The concerns I have with the 15' guns on the small units (140,180,211) are that they add alot of extra feed resistance. To offset this extra resistance the drive roll tension often gets cranked way down to increase the traction on the wire and that extra tension puts a large load on the entire motor drive circuit and on the motor itself which can cause a premature failure in the drive system.
                I will now however have to change my answer in some cases. On the new Millermatic 141 and Millermatic 190 the entire drive system has been redesigned to address those concerns so on these new models a 15' gun is compatible.
                Kevin Schuh
                Service Technician
                Miller Electric Mfg. Co.
                  Kevin, I have a MM211 and a 252 if you ship me a 190 with a 15' wip I will test it for ya.
                    Benny365 one thing to keep in mind, always try and keep your cable as straight and un twisted as possible. You can have more strain on a 10' lead if always twisted or in S ie sharp bends than a 12' lead that is as straight and not twisted.
                    I run a commercial welder with a 15' cable and have burnt well over a 33 lb roll wire in a week and I can tell if I have a twist or sharp bend in cable just in the way it welds or feeds. I always keep my cable as straight as possible or a long curve and relax the gun in my hand and let it untwist, it will always want to untwist and you will know where to hold so it has the least resistance and will feed the smoothest and this will allow the least amount of strain on feed system.
                    Greg
                      Here are some pictures of the bernard gun. I'll post after I've had a chance to hook it up and use it
                      MM 211 W/ Spoolgun
                      Diversion 180
                      Portable Victor O/A
                      Speedglas 9100x
                      My Brain
                        Originally posted by Miller Kevin View Post
                        Benny,
                        Kevin,
                        What would be your recommendation on max length for same on Multimatic 200? I am very impressed with nearly every detail with one exception: after having a 15' gun on my 251 for years the stock gun seems short.
                          ASW,
                          There are 2 different versions of drive systems used in the Multimatic 200. The early ones were the same as the Millermatic 140, 180 and 211 so a 12' gun max would be my suggestion on those.
                          A change was made in early 2014 and they coverted to the same drive system that we are now using in the 141 and 190 so a 15' gun is usable on those models.
                          Kevin Schuh
                          Service Technician
                            Could i swap out the motor drives from 211 and upgrade .id like to be able to run a 15 whip with out problems.
                            Miller Bobcat 225NT onan
                            Millermatic 211
                            Spoolmate 100
                            (Retapped to fit regular mig tips)
                            Work better & less parts to stock.
                            Miller 130xp
                            T/A Dragster 85 (portability 11 pounds)
                            Oxygen/Acetylene torch set 50'
                            2. 4-1/2" grinders
                            1. 9" grinder
                            14" Makita chop saw
                            1/2" Aircat impact gun 900#
                              Thanks! I appreciate the info. It should be the newer version, as it just arrived last week. For now I'll leave it alone, but at some point I'll want to switch it out.
                              ASW, There are 2 different versions of drive systems used in the Multimatic 200. The early ones were the same as the Millermatic 140, 180 and 211 so a 12' gun max would be my suggestion on those. A change was made in early 2013 and they coverted to the same drive system that we are now using in the 141 and 190 so a 15' gun is usable on those models.
