Long time listener, first time caller.
I picked up a Syncrowave 210 complete setup at SEMA back in November to replace my trusty Millermatic 135 and Syncrowave 200. I figured garage space is at a premium, so it would be great to combine both machines into one, especially since the vast majority of the welding I do is typically TIG.
The TIG portion of the machine works well. No complaints there. Inverter TIG FTW.
My complaint comes from the MIG portion, via the Spoolmate 100. I have it loaded up with Hobart .030 hard wire, 75/25 gas, and I've been working on sheetmetal replacement on a car restoration.
The problem is, that while doing tacks with the sheetmetal, the first second or two that the trigger is pulled, the wire just kind of melts and balls up at the end....It's quiet when it does this....and after that initial second or two, it will then will finally transition to the MIG "sizzle" sound. Once it's "sizzling" it seems to be fine for longer beads (on thicker material....not doing long beads on this sheetmetal). Basically once it's finally initiated, it will weld well for as long as the trigger is pulled.
I never had this problem with my Millermatic, and it's VERY frustrating to me.
I've tried it on the AutoSet, and quadruple checked the gas/wire diameter/metal thickness settings.......I've tried adjusting the WFS and voltage both ways.....I've tried adjusting the drag on the spool....nothing seems to work.
Does anybody have any pointers? I know there aren't a lot of people out there who MIG steel with a spool gun....pretty much just Syncro 210 owners I'd imagine.
