Andy,
I am looking at a new machine..found out the old one which still works well is now obsolete and it is better if I just get a new welder..
I am looking at the Maxstar 150 for my little shop..I do mostly automotive work..restoration and such..I will probably get inot some aluminum and stainless work if the machine has that capability..
i very seldom see anything over 3/16 in my shop so having lots of amps is not an issue..what is and issue is being able to crank the amps down to weld things like body metal and such without having burn through in the work..
My choice is between the Maxstar 150 STL or the Maxstar 150 STH..I am hoping to get the right thing in the first place..
I did look at the wire feeders and Gmaw does not seem to be the way to go if one is working on alloy steel (motorcycle frames..grankids seem to break em) or aluminum and stainless..(Stainless maybe make some things for the fish boat..:>)
Your thoughts..??
Thanks
Grampa
Your thoughts..??
Thanks
Grampa
